webminster
Feb 04, 2018Luminary
How "transparent" is AP switching supposed to be?
Orbi router and satellite pair, running 2.1.2.18. Subject says it all... Noticed on Samsung S5 and my brand new LG V30 running Nougat. Seems like as I wander I get switched between satellite and router, with associated disconnect/reconnect on phone. Is that the norm, a hard switchover with reconnection?
I've some issues with clients wandering betwen the two units anyway. I do not have beamforming or MUMIMO options enabled, and have the transmit power at 100%.
- PyroDogApprentice
As far as I know the switchover should happen seamlessly. I have experienced a plethora of problems with my Orbi system but never hard disconnects when roaming. Have you tried wnadering with other devices to see if the same thing happens?
- budyLuminary
I don't seem to have any issue with roaming between my router and my satellite. Actually, there are a number of RFCs regarding roaming of wireless clients and I chose the Orbi system, since they supported all of the current RFCs. However, it also depends on the wifi stack on the client, if it supports the newer protocol additions. So, I can't speak for any Android client, but all of my iOS clients do roam around very well and I never noticed any hiccups.
- PyroDogApprentice
Do you have Fast Roaming enabled under Advanced Wireless Settings?
