Wudimanada
Mar 12, 2021Follower
HP Envy 7640 will not connect thru Orbi RBR40
Currently, I am unable to connect 2 laptops to my printer thru WiFi. Meanwhile our iPhones and IPads work just fine. I am able to connect one laptop to the USB port. I know to disconnect the USB when...
CrimpOn
Mar 12, 2021Guru - Experienced User
At what point does the HP Smart App for Windows fail?
(item 2 on this page: https://support.hp.com/us-en/document/ish_1780623-1698506-16
I doubt this is a contributing factor, but my (personal) practice is to assign IP addresses to things that are 'permanent', such as printers, so that every time they connect to the network, they are at the same IP address.
Would be an interesting experiment to connect the printer using an ethernet cable (temporarily) and see how that goes.
