matt4ksu
Dec 14, 2018Follower
hp probook 470 keeps disconnecting from netgear orbi wifi
Ever since the install of the orbi my laptop will constantly disconnect from the orbi. All other devices are working correctly. No is...
ekhalil
Dec 14, 2018Master
Can it be that your computer's wifi adapter has issues with the 5 GHz band?
I would test to set the computer to only work on 2.4GHz band and see if that would change anything. You can change this in the wifi adapter settings:
