alokeprasad
Jan 04, 2021Mentor
HTTPS access to the web interface.
Do the RBR50 and RBS50 accept HTTPS and HTTP connections from my devices on my LAN? Chrome is warning me that the CA root certificate issued to www.routerlogin.net is invalid. "This CA Root cert...
schumaku
Jan 04, 2021Guru - Experienced User
Well, go over the exceptions and accept... this is it.
alokeprasad
Jan 04, 2021Mentor
OK to accept a cert with uncertain chain of authenticity?
How do we know that the cert wasn't compromised and would allow a man-in-the-middle attack?
NG should distribute valid certificate with the firmware...
- alokeprasadJan 04, 2021Mentor
I see that this has come up before. No progress since then ...
https://community.netgear.com/t5/Orbi/Why-isn-t-ORBI-Login-Secure/m-p/1812545/highlight/true#M72955
- schumakuJan 04, 2021Guru - Experienced User
alokeprasad wrote:OK to accept a cert with uncertain chain of authenticity?
The typical question of people which have not much idea what is required to have no questions asked just showing a "lock" in the browser, just citing some wonderful warnings ...
It's the standard problem when using self-signed certificates. Blunt theory, before accepting the exception you must compare the certificate signature with the one shown. if it's the same, a MITM is unlikely. and of course, as it's a self-signed certificate, there can't be a chain to a root trusted by all your browser makers...
Have your own DNS, your own domain (these two would allow letting a public CA singing your certificate), in case of a local domain your own PKI (certificate authority) with all the infrastructure required to operate a CRL and OCSP and having this integrated with all your browsers and mobile devices? Then you could request Netgear adding a feature to run a CSR to be signed by your CA.
alokeprasad wrote:NG should distribute valid certificate with the firmware...
Well, two possible answers.
- Netgear did ... they had a nicely signed certificate in place, the "lock" came up when using e.g. https.//orbilogin.com/ ... needless to say this required including the (same) private key, and it broke the CA legal requirements.
- What would you suggest?
Where should be this intruder in a home network where all clients connect to the Orbi system wireless resp. more or less direct wired network connections?
Sure, self signed certs are a problem for external web sites and less so for sites (like the router interface) on this side of the NAT.
But there can be malaware like trojans that can get on the LAN change the DNS entries or other aspects of the router settings.
If NG's self signed certs are leaked, the certs cannot be revoked by the usual signing authorities.
Could't NG provide valid (signed by CA authorities) through firmware updates?
Paranoia inside?
