Avohai
Mar 19, 2020Tutor
Huge WiFi speed drops with Orbi RBK53
Hi All, Since the past weeks I've noticed low WiFi performance of my devices (PC and Mac laptops, Iphones) of my Orbi RBS53 (Triband, router + two satellites). My configuration: ISP fiber 1Gbps-> O...
Mar 20, 2020Guru - Experienced User
Avohai wrote:Hi All,
ISP fiber 1Gbps-> Orbi router is wired (CAT 5e) to each of the satellites located in separate rooms at least 40 feet apart.
When connecting devices directly to the satellites via ethernet cable, I get download speeds ~ 500 Mbps (OK). Using the same devices nearby (same room) as each of the satellites, I get WiFi speeds ~ 250 Mbps (OK but huge dropping if you are just standing besides the satellite?). As soon as I walk to next adjacent room (10 feet away), the same device gets WiFi speeds ~ 40 Mbps, which is a huge drop.
I have had my Orbi since Christmas but I noticed the problem becoming worse since the past month or so. I am running the latest firmware.
I know this is not normal because I could get better WiFi speeds in the same rooms with my previous (non mesh) router from Linksys which was 4 years old.
For the price I paid for my Orbi, I was expecting way better performance.
Is anybody experiencing similar issues?
Thanks!
Avohai
Mar 20, 2020Tutor
Hi, thanks. Response in * to your questions below:
* Mfr: DZS (DAZAN Zhone solutions)
* Model: ZNID-GPON-2424A1-NA rev.F1
I
What is the size of your home? Sq Ft?* 2400 sqft
What is the distance between the router and satellite(s)? 30 feet is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected. https://kb.netgear.com/000036466/How-far-should-I-place-my-Orbi-satellite-from-my-Orbi-router* One satellite is 30 ft from the router, the second one is about 40 feet.
* Auto
Any Wifi Neighbors near by? If so, how many?* Two
* WMM is enabled. I will try enabling Beamforming and MIMO/MIMO.
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Set Short preamble instead of Long preamble modes. Save settings and reboot the router and satellite(s).* All above already disable. Preamble mode is in auto.
* Yes.
Thanks!
- FURRYe38Mar 20, 2020Guru - Experienced User
Try setting a manual channel. Be sure to select either 1, 6 or 11 and any not used by your two nieghbors.
As a test, turn OFF the RBSs. Do you still see speeds drops with just the RBR running?
HOw is your ONT confured? I may have a built in wifi and router:
https://dasanzhone.com/product/znid-gpon-2400a1-series/
IF so, This would be a double NAT condition which isn't recommended and would be a cause of problems. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktopv2.5.1.8 working well for me. Been solid since last year.
- AvohaiMar 20, 2020Tutor
Hi, thanks again.
Answer to your questions:
* how do I find out which channels neighbors are using?
* I did that. I did not help.
* I had the fiber company (i3 Broadband, internet provider) here and we confirmed the modem is not set up as router in any way.
Thanks again.
- Retired_MemberMar 20, 2020
Avohai wrote:Hi, thanks again.
Thanks again.
good luck with all oif these useless questions, your problem is with your FW....additionally it looks like your modem has a wifi built in. you'll need to place one of the routers in AP mode. how long have you had this mode?
