Jbode
Jan 13, 2020Follower
Hulu closes randomly
V2.3.5.30 firmware
Orbi rbr50 mesh system with 1 satellite, running with a cox panoramic modem.model TG1682G
Any idea on why it would be kicking me out of Hulu? Before just running off the cox modem it would run fine just laggy at times.
1 Reply
Probably because you're running 2 routers on your network. The TG1682G has an integrated router plus the orbi you're running.
https://kb.netgear.com/30186/What-is-Double-NAT
the 2 easiest options are to either place the Arris in passthrough/modem only mode (check your manual) or to place the Orbi in access point mode. If you decide to place the orbi in AP mode, turn off the wifi on the arris to prevent interference with the orbi.
This leaves only 1 router controlling the dhcp.
