computersteve
Oct 10, 2020Apprentice
I am having a problem with the RBS50y
I keep loosing connection when my device roams to the outdoor Orbi. Is anyone else having this problem. Thanks.
Oct 11, 2020Guru - Experienced User
IS the RBSY connected to a Orbi system or a different wifi router system?
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
computersteve
Oct 11, 2020Apprentice
It's firmware V1.0.0.52. It's connected to an Orbi RBR50. I have it in extender mode & not orbi mode. I did this because if I ever leave the orbi echosystem I just disconnect the orbi RBR & switch to the new router configured as the same SSID as the RBR50. This will allow the RBS50Y to continue extending that SSID without reconfiguring. I have been noticing that even though everything says connected. When devices roam to the RBS50Y they sometimes dont get DHCP or they are connected but no Internet yet I can access the Mywifiext.local page. Everything indicates the RBS50Y its always successfully connected with signal or 192Mbps on the 2.4ghz & signal of 585Mbps on the 5ghz.
- FURRYe38Oct 11, 2020Guru - Experienced User
What version of FW is on the ORbi system?
You might change the RBSY to Orbi mode to see if the same problem happens.
- computersteveOct 11, 2020Apprentice
I understand that this might fix the problem.. However the point of the RBS50Y is it can be setup in extender mode. I didn't notice that problem when it was in "orbi" mode though.
Then there could be a problem when in Extender mode then.
Something to ask NG support about for more help. Maybe some odd problems with current version of FW and Orbi FW.
