barbgkruse
Apr 24, 2019Aspirant
I am trying to hookup my Amazon Echos to my Orbi AC2200 wifi
I am trying to hook up my Amazon Echoes. 2 of the 4 connected to the orbi network okay and the other 2 keep saying they cannot hookup to a public network. It is not a public network. I have reboote...
Apr 24, 2019Guru - Experienced User
what firmware is on your orbi's?
Did you try resetting the Echo's to factory and reinstalling?
How about shutting the 2 connected echo's off and then trying to install the other devices?
How do you have your wireless setup? Is it password protected and with what wireless password settings?
I'm running a current orbi setup with 3x echos 1st gen, 2x echo dot 1st gen, and 1 echo dot 3rd gen without any connection issues so I know it can be done with orbi.
barbgkruse
Apr 25, 2019Aspirant
The firmware is V2.3.1.48
I have not reset the Echos to factory. I will try both of your suggestions.
It is Password protected, but I don't know what you mean by what wireless password settings.
Thanks for your help.
- plemansApr 25, 2019Guru - Experienced User
wpa, wpa2, wep. What protocol did you use. It should be fine if your other echo devices connected. Also be aware that echos struggle with special characters in the wireless password. Worth checking into that too.
