barbgkruse
Apr 24, 2019Aspirant
I am trying to hookup my Amazon Echos to my Orbi AC2200 wifi
I am trying to hook up my Amazon Echoes. 2 of the 4 connected to the orbi network okay and the other 2 keep saying they cannot hookup to a public network. It is not a public network. I have reboote...
barbgkruse
Apr 25, 2019Aspirant
The firmware is V2.3.1.48
I have not reset the Echos to factory. I will try both of your suggestions.
It is Password protected, but I don't know what you mean by what wireless password settings.
Thanks for your help.
Apr 25, 2019Guru - Experienced User
wpa, wpa2, wep. What protocol did you use. It should be fine if your other echo devices connected. Also be aware that echos struggle with special characters in the wireless password. Worth checking into that too.
