port107
Feb 27, 2021Follower
I am trying to use old RBK50 as a bridge or AP
I have an old RBK50 and I would like to use it as a bridge or AP (not sure the right terminology). I want to connect to an existing network wirelessly and use the RBK50 ethernet port to connect a la...
CrimpOn
Feb 27, 2021Guru - Experienced User
port107 wrote:I have an old RBK50 and I would like to use it as a bridge or AP (not sure the right terminology). I want to connect to an existing network wirelessly and use the RBK50 ethernet port to connect a laptop. Can this be done? I can't figure out how to access the admin screen and I already have a working network, so I don't want to go through the network setup again. Just want to access and configure the RBK50 and set it to bride mode. I tried connecting to it via ethernet but it didn't work. I'm hoping I can use it for something, rather than having it just sit in the closet.
An Orbi router (the RBR50 part of the RBK50 package) can be connected only with an ethernet cable from the WAN (yellow) ethernet port. It can be set up in two modes: router and access point. But, both modes require that it be connected to the source network with an ethernet cable.
A different solution is to get a WiFi extender, such as the Netgear EX3700 ($27 on Amazon). WiFi extenders will connect to a WiFi network via WiFi and many (such as this one) provide an ethernet port that can be used for any device with an ethernet port, such as a desktop or laptop.
- CrimpOnFeb 27, 2021Guru - Experienced User
Yet another solution is to purchase an Orbi satellite, such as the RBS40V ($100 on Amazon). This will connect to the Orbi system via WiFi and acomplishes two things (1) it expands the total WiFi coverage area, and (2) it has four ethernet ports that can be used to connect devices. Of course, if the laptop is "smack in the middle" of the existing Orbi WiFi coverage, there is no point in adding another Orbi satellite.
- tim_gageFeb 27, 2021Tutor
CrimpOn wrote:Yet another solution is to purchase an Orbi satellite, such as the RBS40V ($100 on Amazon). This will connect to the Orbi system via WiFi and acomplishes two things (1) it expands the total WiFi coverage area, and (2) it has four ethernet ports that can be used to connect devices. Of course, if the laptop is "smack in the middle" of the existing Orbi WiFi coverage, there is no point in adding another Orbi satellite.
Um..... Great idea. I, in fact, have an RBS40v and love it for the Alexa features. It has GREAT sound.
However, I can confirm that it has only 2 ethernet ports, not 4.
Tim
