nickid
Jun 01, 2020Follower
I am wanting to check if the orbi outdoor wifi range extender (rbs50y) is compatible with the RBR20
I am wanting to check if the orbi outdoor wifi range extender (rbs50y) is compatible with the RBR20 Orbi AC220 Tri-band WiFi Router please
Jun 01, 2020Guru - Experienced User
It is but it'll function at the lower backhaul that the rbr20 uses and not the wider backhaul the rbs50y is capable of when paired with an rbr50.
