Stmgo23
Feb 02, 2020Aspirant
I bought an Orbi RBS40 from Amazon and cannot setup
I bought an Orbi rbs40 from Amazon and cannot set it up because it seems that the previous owner set up a password. Any suggestions?
Feb 02, 2020Guru - Experienced User
Factory reset the RBR and RBS. Press the back reset button for 15 seconds then release. Connect a wired PC to the RBR and walk thru the setup wizard with a web browser.
- Stmgo23Feb 03, 2020AspirantThat worked great! Thank you. Now I can’t get the satellite to pair. It mostly just blinks white lights. Sometimes it will flash one green and one orange really quick. Any suggestions?
- FURRYe38Feb 03, 2020Guru - Experienced User
Are you hitting the sync button in back of the RBR then sync button in back of the RBS while the RBS is in the same room with the RBR?
What FW version do you have loaded on the RBR?
- Stmgo23Feb 03, 2020AspirantYeah I’ve tried that but it can’t seem to find the satellite. I have version V2.5.30
