Stmgo23
Feb 02, 2020Aspirant
I bought an Orbi RBS40 from Amazon and cannot setup
I bought an Orbi rbs40 from Amazon and cannot set it up because it seems that the previous owner set up a password. Any suggestions?
Stmgo23
Feb 03, 2020Aspirant
That worked great! Thank you. Now I can’t get the satellite to pair. It mostly just blinks white lights. Sometimes it will flash one green and one orange really quick. Any suggestions?
Feb 03, 2020Guru - Experienced User
Are you hitting the sync button in back of the RBR then sync button in back of the RBS while the RBS is in the same room with the RBR?
What FW version do you have loaded on the RBR?
- Stmgo23Feb 03, 2020AspirantYeah I’ve tried that but it can’t seem to find the satellite. I have version V2.5.30
- Stmgo23Feb 03, 2020AspirantThe satellite is just steady flashing white.
- FURRYe38Feb 03, 2020Guru - Experienced User
What you need to do is factory reset the RBS. Wire connect a PC to the satellite. Already have the most current FW version files downloaded on to this PC.
When the satellites are reset, wait about 5 minute. The PC will get a IP address from the satellite. The IP address of the satellite will be 192.168.1.250. Use this IP address in a web browser to log in to the satellites web page.
Verify the RBS firmware is up to date and the same version as what is loaded on the RBR.
Use the satellites web page FW update feature to select the FW update file that was unpacked from the .zip file. Then factory reset and then re-sync the satellites to the RBR.
If this fails to get the RBS synced to the RBR, then the RBS may be faulty and needs to be replaced.
