NilsH
Apr 23, 2022Aspirant
I cannot access my Orbi Outdoor Universal Satellite RBS50Y
Suddenly my ORBI RBS50Y started blinking blue and changed the SSID to NETGEAR. I have tried to reset it the normal way and also the 30-30-30 reset but nothing helps. Sometimes the default network SSI...
MarkRamos
May 03, 2022Aspirant
I faced similar kind of issue last time, I am still searching for some proper solution Same issue still no fix to this.
I cant complete the set up as the network drops on average every minute and a half. It lasted up to 10 minutes ONCE and I went through the whole set up and then it disconnected. I thought it wouldn’t be an issue, as the orbi had had its firmware update and everything but now it’s not letting me connect to the network saying I have the incorrect password, and when I do manage to connect it says that the orbi is not set up and or that I do not have internet. I’ve gone through the set up process 3 times already and I’m beginning to regret my purchase.
NilsH
This is exactly the same behaviour as I see. After the first reset there was an SSID NETGEAR.EXT but I could not login. After subsequent resets the was an ORBI SSID that then dissapeared and the password was said to be wrong. Now I cant even see the network but I can see that there is a hidden network, no idea what that network is or what the default passwork should be.
