NilsH
Apr 23, 2022Aspirant
I cannot access my Orbi Outdoor Universal Satellite RBS50Y
Suddenly my ORBI RBS50Y started blinking blue and changed the SSID to NETGEAR. I have tried to reset it the normal way and also the 30-30-30 reset but nothing helps. Sometimes the default network SSI...
KevinLiT
May 11, 2022NETGEAR Moderator
Hi BarryLynn,
I understand that you are having difficulties pairing your satellite to your wireless network.
Please try the following:
- Ensure that your firmware is up to date.
- Bring the satellite close to the router on the initial pairing setup.
Let me know if this helps!!
Best,
Kevin
Community Team
NilsH
May 12, 2022Aspirant
Hi Barry,
The problem i have is even more fundamental, I cannot even connect to the Sattelite since I don't see any Orbi or Netgear network to connect to, just my router.
Kind regards, Nils
