Katers
Sep 11, 2017Follower
I cannot log in to my Orbi RBR50 router
I go to the orbi login and the IP address and it asks for the user name and password and it tells me they are wrong. I have never logged in before so I do not know why they would have changed. Then...
st_shaw
Sep 11, 2017Master
Reset the system using a paperclip in the reset hole on the back of the router. Hold it in for a long time, until the power LED blinks amber. Then login using the default credentials.
