Dcbyrne
Jun 26, 2020Aspirant
I cannot log into my advanced settings on my Orbo RBR50 .. i cant remember my username and password
Good Morning. I tried to log into the sytem using 192.168.1.1 and cannot get past the user name and password. I have tried all the combinations i would have used when setting it up. After a few ...
- Jun 26, 2020
If you factory reset and setup from scratch, if you configure the same SSID name and password you currently use. Your 30+ devices will reconnect after you set this up after the reset. You won't have to touch them. At the very least, you may have to power cycle or reboot them is all, Something ive been doing for years with same SSID name and PW. All my wifi devices reconnect. :smileywink:
Jun 26, 2020Guru - Experienced User
Wire connect a PC to the router and factory reset the router using the back push pin button. Hold it in until the top led turns on AMBER then let go. Power OFF the ISP modem for 30 seconds than back on. Wait for the WHITE led to slowly pulsate on top of the RBR, then log in to orbilogin.com using a web browser and walk thru the setup wizard. This time write down all important information for safe keeping later on.
Set up the same SSID name and PW and your devices will reconnect.
- DcbyrneJun 26, 2020Aspirant
I was hoping there is a way to recover without resetting the orbi. I have over 30 smart devices connected that will need to be reconnected. Doesn't Netgear have the ability to reset without wiping the current router settings?
- CrimpOnJun 26, 2020Guru - Experienced User
Dcbyrne wrote:I was hoping there is a way to recover without resetting the orbi. I have over 30 smart devices connected that will need to be reconnected. Doesn't Netgear have the ability to reset without wiping the current router settings?
When the "Password Recovery" option does not work, the only way to get access is the factory reset. However, all is not lost.
If you configure the Orbi with exactly the same WiFi name and password that it had before, then all 30 devices will connect automatically. What will be lost is any customizing that you may have done. (which ranges from none at all, to "all 30 devices").
For example, some of us "assign" specific IP addresses to devices either (a) so that they always have the same IP address, or (b) to fullfill our desire for "order." All of my IP cameras have IP addresses starting with 192.168.1.51. My Smart Plugs start at 192.168.1.41. My printer is at 192.168.1.4. etc. etc. I also found the Attached Devices display annoying, so I went in and set the Device Name and Device Type for every device. It doesn't affect how they function, but it just annoyed me. People often change the "name" of their router, use a specific DNS service, set up VPN's, etc.
If you want or need to customize the settings, then Yes, it is a very tedious chore. A good practice is to "Save the configuration" to your computer. (Advanced Tab, Administration, Backup Settings. That way, if you get locked out again, you can import the entire configuration at one time.
Thank you so much... i do feel much better doing the reset based on what you just said. I will set up the same WIFI name and Password.
SInce you have smart devices connected to your system perhaps you can give me some advice. I am looking to get into the advanced settings so i can initiate Telenet. I have 4 new devices that i am adding and they all operate on the 2.4ghz bandwidth. I use telenet to "disable" the 5ghz channel for something like 3600 seconds (1 hr) to allow me enough time to make my connections to the new devices. So my question is... How do you work around this issue? Do you utilize Telenet the same way i do?
Thanks again,
Darren
