Dcbyrne
Jun 26, 2020Aspirant
I cannot log into my advanced settings on my Orbo RBR50 .. i cant remember my username and password
Good Morning. I tried to log into the sytem using 192.168.1.1 and cannot get past the user name and password. I have tried all the combinations i would have used when setting it up. After a few ...
- Jun 26, 2020
If you factory reset and setup from scratch, if you configure the same SSID name and password you currently use. Your 30+ devices will reconnect after you set this up after the reset. You won't have to touch them. At the very least, you may have to power cycle or reboot them is all, Something ive been doing for years with same SSID name and PW. All my wifi devices reconnect. :smileywink:
Dcbyrne
Thanks so much for your help and explanation! I will do as you have instructed... fingers crossed lol
take care and have a great weekend!
Jun 26, 2020Guru - Experienced User
