JYDLC
May 07, 2020Aspirant
I cant connect to a certain website I use for work with my Orbi RBR50. Help!
Hi everyone! I am hoping someone can help with an issue I been having with my Orbi RBR50 Current firmware of V2.5.1.8. I am having an issue connecting to a certain website I use for work. The...
JYDLC
May 08, 2020Aspirant
Yes it will work from single wire or even the previous router from ISP company.
No I have done a hard factory reset. I really dont like that idea unless it's my last resort. It would suck to reconnect every single device in my home again.
michaelkenward
May 09, 2020Guru - Experienced User
You can reduce the hassle on that front by using the same SSID and password for wifi after the reset. Your devices should then reconnect automatically.
That is unlikely to revive the problems you describe.
