ByronG
Aug 15, 2017Aspirant
I can't connect to the satellite Orbi RBS50
I received an email to update firmware of Orbi RBS50 but I can't do that due to I can't find it. It doesn´t appear in the app (as satellite or device) or when I try to update manually, even I alread...
- Aug 25, 2017Finally I solved it, I just reset router and satellite, but the key was that you'll have to press reset button during 30 seconds in every device.
Retired_Member
Aug 21, 2017These are some steps on can follow on your end.
1. Power-cycle the satellite (unplug the power cable, wait for 10-15 seconds and plug it back). Your Orbi satellite will automatically try to connect with the Orbi router. If the light on the Orbi router is solid blue, which is a good sign between, check under connected satellites on Orbi routers GUI if you can see the satellite or not.
2. If it is still not visible under connected satellites reset the satellite for 20 seconds, and follow the same steps as in 1.
3. Check the firmware version on the satellite. You will have to open the GUI of the satellite and check the firmware version. Check the IP address acquired by Orbi router. The IP address to open the GUI for the satellite(s) should be in the same range. For example if the IP address of router is 192.168.1.1, use 192.168.1.2 , 1.3, or 1.5 etc to open the GUI of the satellite. There are more ways to open the GUI of the satellite. You can ping me, I will tell you.
I hope this works out for you.
- JudeMillsAug 24, 2017Tutor
Having the same problem after trying to update Satellite's [RBS50] firware from out of the box version V1.2.0.6 to the newest update V1.12.0.18. Upload of firmware showed 100% success but update crashed at that point and could not reestablish connection to the satellite. Have tried recycling the satellite, resetting the satellite and syncing the satellite back to the RBR50 router to no avail. Router IP address is out of the box 192.168.1.1. Satellite no longer shows up on 'Orbi Login Page', so cannot determine the IP address of the satellite. Tried looking using ethernet cable to connect satellite to my laptop and the IP address that shows up is totally different - 169.254.2.143 for that. Typing that address into Explorer gets nothing 'this page can't be displayed' message. Don't know what to do at this point. I have NOT updated the Router's firmware as yet because I'm afraid I'll lose everything. Do I need to do that in order for the router and satellite to be able to communicate? Appreciate any help anyone can give on what to do now to get everything back in sync again. Thanks in advance.
- JudeMillsAug 25, 2017Tutor
Well got one question I had answered - From above, I had updated manually the firmware on my two RBS50 Satellites to the newest version V1.12.0.18 and after a 100% successful upload the manual update program crashed and never confirmed connectivity to the Satellites, and worse, could not get the Satellites to sync with the RBR50 Orbi Router. I did NOT update the firmware on the router fearing total loss of the internet. I could not find an answer anywhere on whether Satellites and Router HAD to be running the same firmware in order to communicate. Well, overnight the RBR50 Router automatically updated itself to the newest version firmware and good news, the Satellites are now synced to the router again and all seems fine with the connectivity. So all hardware DOES have to be running the same firmware in order to communicate.
- ByronGAug 25, 2017AspirantFinally I solved it, I just reset router and satellite, but the key was that you'll have to press reset button during 30 seconds in every device.
