ByronG's avatar
ByronG
I can't connect to the satellite Orbi RBS50
I received an email to update firmware of Orbi RBS50 but I can't do that due to I can't find it.  It doesn´t appear in the app (as satellite or device) or when I try to update manually, even I alread...
  • ByronG's avatar
    ByronG
    Aug 25, 2017
    Finally I solved it, I just reset router and satellite, but the key was that you'll have to press reset button during 30 seconds in every device.
