Slink131
Jan 31, 2018Follower
I can't connect to the satellite Orbi RBS50
One of my satellite disconnected and will not connect. It will either stay purple or color goes away and still does not connect. I moved it right next to my router and it still won’t connect. The othe...
DarrenM
Feb 05, 2018Sr. NETGEAR Moderator
Did you try to factory reset the unit?
DarrenM
