RudySanchez
May 09, 2019Aspirant
I don't see WIFI router ORBI RBR50
Guys, please I need help. I just received my Orbi Kit RBK53. I succesfully set it up and then I started installing manually the firmware upgrades because the automatic option did not work. When I...
- May 13, 2019
Advanced tab---administration---backup settings--backup
May 09, 2019Guru - Experienced User
sounds like its stuck in a boot loop if reset doesn't work and the power button is blinking. Follow this procedure to upload the firmware to it.
https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
This is from this post:
Recommended intermediate migration FW version is v2.0.0.74 for users who have RBR/RBS with old or first released (v1.x) versions of FW. To get from old versions of FW, prior v2.1 or v1.x, users need to first load v2.0.0.74 on both RBS and RBR. Then users can update to v2.3.x versions of FW.
RudySanchez
Thanks mate. I will try tomorrow. Honestly I'm tired with this **bleep**. Now I just want to sleep. I wasted almost 15 hours in this. Thanks again and I let you know once I've done it.
Kind regards.
