RudySanchez
May 09, 2019Aspirant
I don't see WIFI router ORBI RBR50
Guys, please I need help. I just received my Orbi Kit RBK53. I succesfully set it up and then I started installing manually the firmware upgrades because the automatic option did not work. When I...
- May 13, 2019
Advanced tab---administration---backup settings--backup
May 10, 2019Guru - Experienced User
After v2.0.0.74 is loaded, load the RBS first with v60 FW.
Then you'll need to load the RBR with v212 firmware first, then apply v60 FW.
Factory reset after v60 is loaded and setup from scratch.
RudySanchez wrote:
One last question. After the instalation FW 2.0.0.74 and the hard reset, I will need to set up everything from the begining, right? ie. I will need to run the setup application as I did when I got out of the box?
RudySanchez
May 11, 2019Aspirant
Guys
It took some time to my old Geek skills to comeback but finally I did it. Everything seems to be ok and my hardware is on the latest FW version.
Thank you all for the support and tips. You really saved the day.
Very much appreciated.
Kind regards.
- FURRYe38May 13, 2019Guru - Experienced User
Glad you got it updated now. Be sure to backup the routers configuration to file for safe keeping. Please mark your thread as solved so others will know.
Enjoy. :smileywink:
- RudySanchezMay 13, 2019AspirantYes I will but one last question. How do I backi it up the routers config files? Where are they?
- plemansMay 13, 2019Guru - Experienced User
