Abackman
Oct 09, 2018Follower
i forgot my security question Orbi router RBR50
When i try to login as Adm the defautl password doesn’t work not my normal password.
So I choose “forgot my password” it the my security questions doesn’t work
how do I overcome this ?
1 Reply
Wire connect a PC to the router and factory reset the router using the back push pin button. Hold it in until the top led turns on AMBER then let go. Wait for the WHITE led to slowly pulsate, then log in to orbilogin.com using a web browser and walk thru the setup wizard. This time write down all important information for safe keeping later on.
