Sevo123
Apr 27, 2018Apprentice
**I found a Connection issue Resolution for wired backhaul !! **
Ok so Everytime my power would go out or and update happened/ or any way my orbi system would have to turn off my connection would just die with my rbk53 unit. Mainly because once I had my ethernet wi...
Dsdeck
Apr 27, 2018Tutor
Sevo123,
Thank you so much! Every time my system would restart devices wouldn’t sync I couldn’t access the main Orbi through web interface. I would have factory reset each time.
Today it went into psycho Orbi mode so I unplugged all ethernet plugs going into Main Orbi. Power cycled, waited a few minutes and plugged all ethernet cables back into the main Orbi and BAM! All is good in my Orbihood.
The Orbi system is outstanding when it’s up and running. Thanks again.
Sevo123
Im So glad I was able to help!
