Sevo123
Apr 27, 2018Apprentice
**I found a Connection issue Resolution for wired backhaul !! **
Ok so Everytime my power would go out or and update happened/ or any way my orbi system would have to turn off my connection would just die with my rbk53 unit. Mainly because once I had my ethernet wi...
DaveHamilton
May 20, 2018Guide
I have an RBR50 and two RBS50 units. Tried this with one of the RBS50 units and once I plugged in Ethernet, it basically became unresponsive. Left it for 15 minutes with no change, so I unplugged. Within a minute or two everything came back up just fine.
I test lots of mesh here, most recently the eero and Velop tri-band. Neither of those has any issues using Ethernet backhaul in exactly the same locations/configuration.
I do have several dozen Sonos devices, but that hasn't been an issue with any other mesh.
- FURRYe38May 21, 2018Guru - Experienced User
Any network LAN switches in between the router and satellite? If so, whats the Mfr and model# of these swithces?
- DaveHamiltonMay 21, 2018Guide
I have a TrendNet TEG-S16D in between, yes. Straight-ahead, "dumb" Gigabit switch. Passes STP no problem (given that all my Sonos stuff works just fine across it).
- FURRYe38May 22, 2018Guru - Experienced User
I would do this, remove the switch or bypass the switch.
Do a factory reset on the router and 1 satellite. Set up from scratch, add 1 satellite first via wireless. Then connect this 1 satellite directly to the router and give 5 minutes. Look for the top LED to turn BLUE. Can you get to this stage?
