Hsc1102
Nov 04, 2019Apprentice
I Give Up, Returned the RBK53
That’s it. After years of connection issues and promises of improvement with firmware upgrades only to be left waiting for another firmware upgrade to fix the previous issues , I decided to return the...
Retired_Member
Nov 05, 2019
Hsc1102 wrote:
That’s it. After years of connection issues and promises of improvement with firmware upgrades only to be left waiting for another firmware upgrade to fix the previous issues , I decided to return the RBK53. Thank goodness for Costco and their generous return policy!!!
Any recommendations?
That's too bad. If you return it due to firmware issues, I believe you'll all the others face the same problem. They key is stay away from manual updates. If your system is working, why upgrade the firmware?
Hsc1102
Nov 06, 2019Apprentice
I've been on some 'fairly stable' firmware versions before, but netgear just never seems to get it right. This day and age with the complexity of technology all companies experience issues with a version of their firmware, but it just seems like netgear was never able to get it right. One version, I would have continuous connectiveity at slower than expected speeds and other versions I would have fast speeds but it would constantly disconnect especially when I am on a conference call for work. This is not what you expect for a ~$400 system that promises fast speeds and big range. Seems like firmware limited the ORBI's potential.
- Retired_MemberNov 06, 2019
Hsc1102 wrote:Seems like firmware limited the ORBI's potential.
How was your firmware installed?
- superczarNov 08, 2019Apprentice
I would second the fact that there is something fundamentally off about the Orbi firmware.
I still love the hardware and no other router/mesh comes close in performance when the system works fine.
However the way the firmware distribution is managed + the inherent bugs in the code base (I presume) make the experience far less positive than otherwise.
My initial setup a year ago took over 2 days of trubleshooting before I got it stable
Adding a new satellite a few weeks ago broke a lot of things and took almost a week of hit & trial to get things back to normal (Eventually settled by setting Orbi as AP , downgrading firmware to 2.1.something and blocking internet access to all Orbis - to prevent auto updates)
Oh, and each time it reboots (say after a power failure), the whole network takes severeal minutes to come up and hours to fully stabilize. Short Brownouts and blackouts are fairly common in my town and I had to eventually move the Orbi power to a small UPS to avoid this
I think there is a lot more happening on the layer 2 switching on the Orbi than what happens on a traditional router and something about it is off
- Retired_MemberNov 08, 2019
superczar wrote:I would second the fact that there is something fundamentally off about the Orbi firmware.
Please keep in mind that the only firmware pushed to users automatically are ones with major revisions. All others are up to the users. May not be a 100% fool proof system, but if your network is working and you login to the router and see that a update is 'available', shouldn't you ask yourself..."why?", unless you like living on the edge and particiapting in NGs new beta test group.
- Hsc1102Nov 08, 2019Apprentice
It was installed via the orbilogin page and as I always do, I did the factory reset.
Hsc1102 wrote:It was installed via the orbilogin page and as I always do, I did the factory reset.
You did a factory reset and you still have problems?
