gvarsity
Aug 28, 2022Aspirant
I have 1 RBR50 router and 1 RBS50 satellite losing connection to router
Since this morning I have been having to power cycle the orbi every hour or two because it loses connection to the router. Ran firmware updates and the router has been consistently solid. I have re...
ekhalil
Aug 29, 2022Master
What is the model of the ISP router/modem that Orbi is connected to?
- gvarsityAug 29, 2022Aspirant
ATT Fiber ARRIS BGW210-700
- FURRYe38Aug 29, 2022Guru - Experienced User
Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktopTry option #2 first...
I will check these options out. We have been using this system as is for two years without a problem and we did have a ATT Router/Modem replacement maybe two months ago. Again without a hitch until yesterday. Is it common to work for a while and then crater or was there perhaps an update on their side that I don't see that would cause this behavior?
Thanks'
- ekhalilAug 29, 2022MasterARRIS BGW210-700 is a router. Is Orbi also set in Router Mode? Can you test and see if things get better if Orbi is in AP mode.
