gvarsity
Aug 28, 2022Aspirant
I have 1 RBR50 router and 1 RBS50 satellite losing connection to router
Since this morning I have been having to power cycle the orbi every hour or two because it loses connection to the router. Ran firmware updates and the router has been consistently solid. I have re...
ekhalil
Aug 29, 2022Master
What is the model of the ISP router/modem that Orbi is connected to?
gvarsity
Aug 29, 2022Aspirant
ATT Fiber ARRIS BGW210-700
- FURRYe38Aug 29, 2022Guru - Experienced User
Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktopTry option #2 first...
- gvarsityAug 29, 2022Aspirant
I will check these options out. We have been using this system as is for two years without a problem and we did have a ATT Router/Modem replacement maybe two months ago. Again without a hitch until yesterday. Is it common to work for a while and then crater or was there perhaps an update on their side that I don't see that would cause this behavior?
Thanks'
- ekhalilAug 29, 2022MasterHaving 2 routers in the network can cause many intermittent and unpredictable issues.
Is also wifi enabled on the ISP router? If yes then that also might cause interference and speed issues, among other things!
- ekhalilAug 29, 2022MasterARRIS BGW210-700 is a router. Is Orbi also set in Router Mode? Can you test and see if things get better if Orbi is in AP mode.
