mbod
Mar 20, 2019Follower
I have a Orbi RBR50. Also upgraded to Altice modem through optimum
I have optimum Altice service using an Arris TM822G modem. When I turn on the Orbi my television starts to pixelate.
Mar 20, 2019Guru - Experienced User
How close to the tv are you? There can be some RF bleedover from the RBR50 so if you're close to the tv or if your coax barrel connectors aren't very good you can get interference. This can also happen with cheap/crappy coax cables. Try moving your router further away.
