denise321
Oct 16, 2024Aspirant
I have a router with one satellite (RBS50V2) and I wish to extend with additional satellites.
I have a router with one satellite (RBS50V2) and I wish to extend with additional satellites. I bought a used set online that comes with one router and two satellites (RBS50). Can these be combined? ...
CrimpOn
Oct 16, 2024Guru - Experienced User
Yes, more satellites can be added.
No, it is not necessary to use the original RBR50 router. The only significant difference is that the "v2" router has no USB port. Apparently Netgear had "plans" for the USB port that were abandoned. (Just like there was probably a reason to include Bluetooth, which also never materialized.)
It is customary to do a Factory Reset on the additional satellites before attempting to use the "Add Orbi Satellite" feature.
One obstacle that has plagued users wanting to add the newer AX satellites to their system has been when the satellites are loaded with different firmware than the router. What firmware is currently loaded on the existing (working) router and satellites?
- denise321Oct 16, 2024Aspirant
Thanks so much for the reply. I just logged in and I see Router Firmware Version V2.7.4.24. Is that what you're looking for? When I'm trying to add one of the satellites, it's giving me a magenta light instead of solid white.
