AACTech1
Sep 05, 2020Follower
I have a spare RBR50 lying around
I have a network setup consisting of an RBR50 in router mode that is performing DHCP. I have two RBS50 satellites connected wirelessly to this router in a school environment. I now have a spare RBR50...
Mstrbig
Sep 05, 2020Master
AACTech1 wrote:I have a network setup consisting of an RBR50 in router mode that is performing DHCP. I have two RBS50 satellites connected wirelessly to this router in a school environment. I now have a spare RBR50 lying around that I'd like to add to the existing mesh network to improve the Wi-Fi because it's a large building. Can this RBR50 in AP mode act like a satellite and connect to the mesh network with no ethernet cables? If I push its sync button and the sync button on a satellite, will it connect? How about if I push its sync button and the sync button on the main router RBR50?
If it won't connect wirelessly, perhaps I could run an ethernet cable within the same room between the spare RBR50 in AP mode and one of the satellites. Will it work then?
Thank you in advance for your advice.
Rodney
No it will not work.
