AACTech1
Sep 05, 2020Follower
I have a spare RBR50 lying around
I have a network setup consisting of an RBR50 in router mode that is performing DHCP. I have two RBS50 satellites connected wirelessly to this router in a school environment. I now have a spare RBR50...
CrimpOn
Sep 05, 2020Guru - Experienced User
AACTech1 wrote:If it won't connect wirelessly, perhaps I could run an ethernet cable within the same room between the spare RBR50 in AP mode and one of the satellites. Will it work then?
Mstrbigis correct. The spare RBR50 can never be used to extend the Orbi mesh. Because it must be connected through the WAN (yellow) ethernet port, what can be done is to wire it to any part of the network (router, satellite, switch) and set it in access point (AP) mode. This will create a new WiFi access point, just as if a WiFi access point from any vendor was attached to the system.
There are two "downsides" to this:
- Because of the requirement for ethernet connection, it may be impractical to place the RBR50 far enough away from the existing Orbi units to provide much "expansion". Having it in the same room would usually result in them having totally overlapping radio coverage, which is actually worse rather than better.
- Since it will not be part of the Orbi "mesh", devices will not switch automatically between this access point and the Orbi access points. This leads to things like, "why is my phone suddenly running so slow? Oh, yes. I forgot to switch networks. Dagnabbit."
So, this expensive RBR50 is actually less useful than a $50 WiFi extender from almost any vendor (because of the need for ethernet connection).
Bummer.
Mstrbig
Sep 05, 2020Master
Mstrbigis correct.
Bummer.
There's always the Satellite conversion hack. I've done it a few times.
I just don't like to mention it because of the possibility of the RBR50 getting bricked by a novice. But if it's a spare the owner doesn't want to sell it, it is an option. An internet search will bring up the procedure.
