Drj37
Mar 23, 2018Aspirant
I have Cox ultimate 300 down 34 up
So my download speed is always over 300 but now my upload is around 8-10 any help it started doing it on my last orbi so I figured it was the orbi took it back to Bestbuy exchanged it out for another...
Mar 23, 2018Guru - Experienced User
If you have upgrade FW to beta, yes, please try the reset and set up from scratch. I would avoid setting up QoS, Traffic Meter or Access Controls.
Try a reset then do a speed test with a ethernet connected PC. Should be getting to spec speeds...
Just making sure the ISP modem doesn't have a built in router is all.
