armiller4
Jul 28, 2020Aspirant
I have the CBR40 and a RBS20 and my satellite is showing less connectivity than my CBR40
Hey all! I need some advice. I have a CBR40 which came with RBS20. My RBS20 is showing only one bar of signal strength. We live in an old house, but the Router/Modem is about 25 feet away from the S...
armiller4
- CBR40: V2.3.5.12
- RBS20: V2.5.1.16
30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
- Cool- I moved it up higher in the house! It probably only gave me an extra 10 feet, but I'm trying!
- Got it! Made those adjustments
https://kb.netgear.com/19668/Link-Rate-and-Transfer-Speed
- Oof! 14 are showing, half of those are the same network split out for 2G/5G
Try enabling Beamforming and MIMO(MIMO may or may not be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
- Got it! I've made these changes
- Armor
- Verified not on
- Circle
- Verified not on
- Daisy Chain
- Turned off
- Fast Roaming
- Verified not on
- IPv6
- Verified not on
- Set 20/40Mhz Coexistence to 40Mhz only
- Haven't done this yet
- Set Short preamble instead of Long preamble modes.
- Done
- Save settings and reboot the router and satellite(s).
- Done
https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M970...
- Thanks for this tip, I adopted the following
- Channel 1 for 2.4 Ghz and Channel 36 for Ghz
- I am concerned I don't know enought about IPs anymore to set a static IP
Has a factory reset and setup from scratch been performed since last FW update? See if this changing any behaviors on the RBS.
- When I was moving it I ended up having to do this to get it re-synced
You might try getting an EX7500 or EX7700 to connect up as a wifi extender to the CBK40 system. Yes RBS50Y outdoor would connect.
- Thanks! That is very helpful and I appreciate the confirmation!
Results from configuration changes and moving the router:
- It looks like I'm still just getting one bar of connection. :/ Do you think it could be due to the house having plaster, etc? Would the extender help with that or should I seek to try to move the router around downstairs? I think I have about 8-10 feet I could move it due to the cable having some leeway.
Thanks again for the help and advice!!
Jul 30, 2020Guru - Experienced User
Something to try and see.
possible faulty RBS aswell...
