wburnham
Oct 14, 2023Follower
I have the following product Orbi AC3000 Tri-band WiFi Router (RBR50)…IP issues…need help
Hello. I have the following product Orbi AC3000 Tri-band WiFi Router (RBR50) With some of the satellites that go with this. It mostly works great. My AT&T Modem has a 10.0.0.X IP address and ...
Oct 14, 2023Guru - Experienced User
Its because you're running a double nat and have some connecting to the orbi and some to the ATT device.
A double nat happens when you cascade more than 1 router.
https://kb.netgear.com/30186/What-is-Double-NAT
Fixes? There’s 3 options but only use 1.
1. Put the modem/gateway in modem only/pass through mode. This disables its routing functions.
2. Leave the modem/gateway in router mode but put the Netgears IP address into its DMZ. This forwards the data to the netgear. You can either leave the modem/gateway’s wireless enabled or disabled. Just make sure its using a different wifi channel to prevent interference
3. Put the Netgear into access point mode. This disables its routing functions. Wifi/ethernet still works but it does disable some features.
https://kb.netgear.com/26765/Which-features-are-disabled-on-my-NETGEAR-router-when-it-is-set-to-AP-Mode
