lenovoze
Jul 18, 2017Follower
I have the Orbi 2 pack - should it say 2 satellites connected or just 1?
Hello! Just a quick question... I own the orbi 2 pack and have it setup around the house. When I log into orbilogin site and view the "attached devices" section, how many "satellites" should ...
- Jul 18, 2017
If you have the two pack, you have one router and one satellite. So, you should show one satellite connected. When you log into "orbilogin" you are actually logging into the Orbi router.
st_shaw
Jul 18, 2017Master
captain_phaser
Jul 18, 2017Apprentice
In addition, under the attached devices page you can view the satellite's IP address. Typing that into your browser will let you log in to the satellite specifically (using the same login info as the router). From here you can check which devices are specifically connected to the satellite.
