fernandr
Mar 13, 2024Guide
I have two satellites tied to my ORBI router
I have two satellies tied to my ORBI router but one of the satellites is not password protected to access by devises. The other Satellite and Router is password protected. How do i get the satellit...
fernandr
Mar 13, 2024Guide
I have two satellies tied to my ORBI router but one of the satellites is not password protected to access by devises. The other Satellite and Router is password protected. How do i get the satellite password protected? Thank You
Mar 13, 2024Guru - Experienced User
Have you tried factory resetting it and then re-syncing it with the router?
- fernandrMar 13, 2024Guide
Thanks. I tried it but did not resolve the problem.
- plemansMar 13, 2024Guru - Experienced User
Are you using a hardwired backhaul or wireless?
where do you see that its still open?
What is it showing under the attached devices page for the satellites?
I am using wireless. I see that it not secure thru my device. See the below screenshot. Satellite if concernis 192.168.21. Thanks
