RDMc
Sep 13, 2019Follower
I installed an ORBI 2200. iPhones and laptop WiFi connects OK. I can’t connect our iPad.
Model is RBK43 AC2200 I'm able to connect iPhones and laptop to WiFi. Can’t connect iPad. Error messages are either no internet connection or password incorrect. I didn’t have any problem with...
Sep 13, 2019Guru - Experienced User
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
Be sure to forget any prior wifi profiles on the phones.
Have you set up the Orbi system for the same SSID and PW used in your prior wifi router?
