whigmaleerie's avatar
whigmaleerie
I just got off the phone with their support, which was useless
I just got off the phone with their support, which was useless. They told me to separate my network and rename them different names for the 2.4GHz and 5.2Ghz bands. I have a boatload of devices conne...
  • whigmaleerie's avatar
    whigmaleerie
    Dec 17, 2023
    Yes, it's really annoying to have to dig for tweaks anymore. It's just not that hard to code for.
    Anyway, I also thought about turning off SSID broadcast on the 5GHz network yesterday. By itself it still didn't work. What did work was also turning off 20/40MHz coexistence, essentially favoring the 2.4GHz network. Together, that finally worked. What a pain.
    Thanks for taking the time to try to help. I forwarded the solution that worked for me to them, but you should definitely hit them up for a contract to improve their product and customer experience.
