Sevo123
Jan 08, 2018Apprentice
I need help Please!!!! Mesh issues
Hi Everyone, I need your help! So I have a long rectangular property and I have a front house then a garage then a backhouse at the end of the property. Total about 13,300 sq ft. I bought a rbk53 sys...
Sevo123
Jan 10, 2018Apprentice
Ok so I spent about 4 hours talking to Netgear support regarding the daisy chain which is supposed to be working perfectly. Well everyone dont be shocked after 4hours of multiple times testing on my orbi system their highest level tech rep told me there is a issue with the daisy chain and it’s probably affecting everyone. They are ganna try to fix it in 24hours or get some more data from my orbi system to try and fix it. The satellites wont connect to eachother even when they are closer than the router they still will connect to the router thats 100ft + away and get a poor signal. I am running the lastest software (beta one that was released). Its been a mess hope they fix this asap for everyone. You all should confirm if you have daisy chain on most likey the satellites are not talking to eachother but talking to the router even if the router is further out it will only not talk to the router if it doesn’t see the router signal which would mean the router has to very far away. I will keep u all updated on what happens.
