Excalibur_2019
Apr 10, 2020Aspirant
I need help with RBR20 Orbi and the issue of NAT type 3 on playstation 4
Hi. I bought the Orbi over a year and didn't paid attention of the issue of NAT type 3. I have the Orbi wifi router and one satellite. I just updated the firmware which is V2.3.5.30. Recently, I trie...
Apr 10, 2020Guru - Experienced User
What modem are you connected to?
- Excalibur_2019Apr 10, 2020Aspirant
The modem's name is TG2492LG-LIB
- plemansApr 10, 2020Guru - Experienced User
the TG2492LG is a modem/router combo device. Its why you're having nat issues. Its called a double nat. It happens when you're running 2 routers on the same networks both running in router mode.
https://kb.netgear.com/30186/What-is-Double-NAT
the 2 easiest fixes? You can either put the arris device in passthrough/modem only mode (contact isp for help with this) or you can place the netgear in AP (access point) mode.
I see. i'll definitely try these solutions. So, how do i make the netgear in access mode? If it doesn't work, I'll call the ISP for help.
