Excalibur_2019
Apr 10, 2020Aspirant
I need help with RBR20 Orbi and the issue of NAT type 3 on playstation 4
Hi. I bought the Orbi over a year and didn't paid attention of the issue of NAT type 3. I have the Orbi wifi router and one satellite. I just updated the firmware which is V2.3.5.30. Recently, I trie...
Excalibur_2019
The modem's name is TG2492LG-LIB
Apr 10, 2020Guru - Experienced User
the TG2492LG is a modem/router combo device. Its why you're having nat issues. Its called a double nat. It happens when you're running 2 routers on the same networks both running in router mode.
https://kb.netgear.com/30186/What-is-Double-NAT
the 2 easiest fixes? You can either put the arris device in passthrough/modem only mode (contact isp for help with this) or you can place the netgear in AP (access point) mode.
- Excalibur_2019Apr 10, 2020Aspirant
I see. i'll definitely try these solutions. So, how do i make the netgear in access mode? If it doesn't work, I'll call the ISP for help.
- plemansApr 10, 2020Guru - Experienced User
here's the instructions
https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point
Thank you for the help. Unfortunately, I did made the netgear as an access point, however it didn't change much. The netgear is in the living room and i use the ps4 in my room, using the satellite as wifi. I should probable call the ISP so they can assist me with what you mentioned before.
