Ctmangrum
Aug 25, 2021Initiate
I need to connect 1 device to 2.4ghz and others can be 5ghz
So I have a Schlage wifi deadbolt that can only connect to 2.4ghz and everything else I have can use 5ghz. How can I use 2.4ghz for that device only. Using the smartconnect settings in the router auto...
CrimpOn
Aug 25, 2021Guru - Experienced User
The lock has only a 2.4G radio chip in it. It cannot detect or connect to 5G. It will connect to 2.4G automatically. You need do nothing.
