SLK-Purdue
Jul 31, 2021Luminary
I object in the strongest possible terms (ref new firmware auto update and removing TELNET option)
I want to object in the strongest possible terms to NG updating my Orbi firmware overnight even though I had set the parameters for no auto-update. Additionally, now that I have new firmware (v2....
mmz06
Aug 13, 2021Guide
Hi there,
Facing the same issue, I could restore telnet access using the updated version of telnet-enable2.py, enabling back Telnet using V2.7.3.22: https://github.com/bkerler/netgear_telnet
I could push all my existing custom configuration (upnpc, automation, etc.) from here.
Hope this will help you as well...
- CrimpOnAug 13, 2021Guru - Experienced User
My goodness gracious. This works on my RBR50 with firmware v2.7.3.22!
I have tried the python script on Linux.
Will try it on Windows and also the compiled versions.
Thank you. Thank you. Thank you.
