SLK-Purdue
Jul 31, 2021Luminary
I object in the strongest possible terms (ref new firmware auto update and removing TELNET option)
I want to object in the strongest possible terms to NG updating my Orbi firmware overnight even though I had set the parameters for no auto-update. Additionally, now that I have new firmware (v2....
CrimpOn
Aug 14, 2021Guru - Experienced User
User error indeed. telnet-enable2.py works on Windows 10 once the parameters are entered in the correct order. And, the author's warning about Windows Defender flagging the exe file as evil is correct. Cannot even extract it from the zip file.
And... the Attached Devices web page from SLK-Purdue works on firmware v2.7.3.22 as expected. Sorts on every column.
Thanks for diagnosing my error.
UnhappyOrbiUser
Nov 25, 2021Star
Ugh, what am I missing. None of these work on an RBR40 at v2.7.3.22 ?
nte: FAIL. No ACK message received.
telnet-enable2.py doesnÂŽt work either.
Using the LAN MAC & IP address, router is in AP mode not that this should matter?
- CrimpOnNov 25, 2021Guru - Experienced UserI use the Python script every time my RBR50 is rebooted. Have no idea why it would not work on the RBR40. On my first attempts months ago I did not include all of the parameters in the right order.
- koa132435Oct 09, 2022Star
You all are very lucky. I have tried all of them on the RAX200 with no luck. đ
I would like to understand the reverse engineering part. I can do some python but missing the recipe.
