DoDK
Dec 11, 2020Aspirant
I replaced with RBK50, But still 866mbps speed at router?
Hello, All. I hope all you guys are doing well in COVID-19 Pendemic situation. I've been using AT&T1gbps fiber internet plan more than 2 years. I thought 1gbps meaning is download speed + up...
Dec 11, 2020Guru - Experienced User
Is this speed result wired or wireles? If wireless, then you not see more than 866Mpbs or anything near 900Mpbs on wireless. Most wifi devices max out at 400-500Mpbs on 5Ghz AC.
If you have wired PC or laptop, then you should see near 900Mpbs on the 1000Mpb connection rated LAN cable line with the PC or laptop.
If your ISP modem has a built in router, This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
- DoDKDec 11, 2020Aspirant
No, I've checked the speed test in Orbi App. So, It is speed test Orbi router and AT&T modem(Pace 5268ac) with wired option.
AT&T Modem already in DMZ+ mode which is similar Bridg mode and I change Orbi BRB50 into router mode.
But whether I get RBR50 with AP mode or Roouter mode, Speed is always 500~550 in download and 300~330mbps in upload.
Probvably it should be 800 ~900 in bothway because, it is RBR50 which has 1733mbps Backhaul speed.
- FURRYe38Dec 11, 2020Guru - Experienced User
Wired Yes, Wiress no. The wireless backhaul speed is between the RBR and RBS ONLY. Not for wireless connected devices.
Front haul between the RBS/RBR and any connected wireless devices that supports that rate on 5Ghz AC for the connection rate ONLY will be 866Mbps.
Wired Yes, Wireless no.
