DoDK
Dec 11, 2020Aspirant
I replaced with RBK50, But still 866mbps speed at router?
Hello, All. I hope all you guys are doing well in COVID-19 Pendemic situation. I've been using AT&T1gbps fiber internet plan more than 2 years. I thought 1gbps meaning is download speed + up...
DoDK
No, I've checked the speed test in Orbi App. So, It is speed test Orbi router and AT&T modem(Pace 5268ac) with wired option.
AT&T Modem already in DMZ+ mode which is similar Bridg mode and I change Orbi BRB50 into router mode.
But whether I get RBR50 with AP mode or Roouter mode, Speed is always 500~550 in download and 300~330mbps in upload.
Probvably it should be 800 ~900 in bothway because, it is RBR50 which has 1733mbps Backhaul speed.
Dec 11, 2020Guru - Experienced User
Wired Yes, Wiress no. The wireless backhaul speed is between the RBR and RBS ONLY. Not for wireless connected devices.
Front haul between the RBS/RBR and any connected wireless devices that supports that rate on 5Ghz AC for the connection rate ONLY will be 866Mbps.
- FURRYe38Dec 11, 2020Guru - Experienced User
Wired Yes, Wireless no.
- DoDKDec 11, 2020Aspirant
I menat why Speed test in Orbi showing 500 ~ 550 mbps in download and 300 ~ 330 mbps in upload. That speed test is not for wireless.
RBR50 is wired to AT&T modem , and AT&T modem is getting 900mbps in bothway from AT&T. But, Why RBR50 can't show that much speed If I check RBR50 speed test in ORBI App.
What others have seen with your model mode:
Modem FW may have broke good speeds between the modem and Orbi in router mode:
https://community.netgear.com/t5/Orbi/RBK50-Speed-Throttling-Wired-and-Wireless/td-p/1673291/jump-to/first-unread-messagehttps://community.netgear.com/t5/Orbi/Installing-Orbi-behind-ATT-Pace-5268AC-gateway/td-p/1234191
https://community.netgear.com/t5/Orbi/Netgear-Orbi-and-ATT-Pace-5268-Router/m-p/1786833/highlight/true#M68004
https://community.netgear.com/t5/Orbi/ATT-fiber-BGW210-and-costco-RBR50-RBS50/m-p/1868313#M83488https://community.netgear.com/t5/Orbi/How-I-fixed-our-intermittent-internet-connectivity-problems-with/td-p/1688722/jump-to/first-unread-message
https://community.netgear.com/t5/Orbi/Orbi-RBR50-Slow-Wired-WAN-after-2-2-1-210-Upgrade/m-p/1676934/highlight/true#M47457
