Mayhugh1
Feb 28, 2018Apprentice
I thought I was one of the lucky ones ...
I've stated before that I must be one of the lucky ones because I don't seem to be having all the problems that many others have been experiencing. However, after some detective work during the past ...
naerok
This is an issue known throughout some of the community here of the satellites leaking memory and download speeds degrading/disconnecting.
The solution for this is to reboot the satellite and some orbi users have had to purchase smart outlets / timers to power cycle their satellites once per day while they are sleeping / away from home - it's rediculous.
see this guy: https://community.netgear.com/t5/Orbi/Orbi-satellite-dropping-connection/m-p/1512445#M24230
Don't listen to the netgear shills that give you the same bs about trying to disable beamforming/mimo or moving the satellites closer to the router. Waste of time until netgear releases a fix.
